anwei7208
Junior Member level 1
cadence rtl compiler
I had a tested verilog code. When I used cadence RTL compiler for synthesis, I have the following error message:
Error : Could not connect positional port. [CDFG-404] [elaborate]
: Cell 'sram_16_256' has no defined positional ordering in file '..........' on line 241
: Error during elaboration
Can anyone explain to me what is "postional"? Thanks very much.
By the way, 'sram_16_256' is a pre-generated register file block.
