Maybe someone can help me with the following problem.
I want to build a nios based system with a boot program in internal ROM, just like the nios tutorial. Only there is on problem:
Problem:
During generation of the nios system in SOPC-builder I get the following error:
"nios-elf-gcc not found"
I suspect that that SOPC-builder is not linked to the nios-elf-gcc directory path.
I have entered the path in the "EDA tools settings" in Quartus but this has no effect.
Also adding the nios-elf-gcc path to the path variable has no effect.
Does anyone have experences with the same problem?
