Hi all, i also attach my project file to this reply. do take a look and let me know if you spot some other mistakes. i have not simulate it yet as i do not have the full version of feko. i got to go back to uni to do that. also in this reply is the correspondence between me and element7k who has been helping me. this reply is also for people who r facing the same problems as me
cheers
Alvin
Hi element7k,
> thanks for the prompt reply, i have attached the journal to this mail.
> the shorting pin is not attached? how is that so? do i have to make sure that
> the pin is shorted to the edges of the triangle or at the corners? how do i
> create two additional points on the balun and dipole structure?
> thanks alot. i really appreciate it.
> cheers
> Alvin
> > Hello alvin,
> > I looked briefly at your structure and found that the shorting pin
> > (nodes R & S) is not attached to any of the surface triangles. They
> > should be attached. (e.g. create two additional points on the balun
> > and dipole structure) Try attaching them and I think your problem
> > should go away.
> > Hope this helps.
> > Cheers,
> > Element7k
