Help Needed with Code Conversion
hitesh joshi
Newbie level 6
Newbie level 6
i have C language code for AVR ATTINY 85. As i dont have a AVR Studio for compiling it into hex code. Can anyone convert it into Hex and send me the conversion file.
Yours help will be appreciated.
Regards
Hitesh Joshi
heres the code
#define trigPin 4
#define echoPin 3
#define motor 0
const byte RANGE_FAR = 60, RANGE_MED = 30, RANGE_CLOSE = 15,
SENS_HIGH = HIGH, SENS_MED = 200, SENS_LOW = 150;
void setup() {
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(motor, OUTPUT);
  //ON Indicator:
  digitalWrite(motor, HIGH);
  delay(200);
  digitalWrite(motor, LOW);
  delay(100);
  delay(200);
  delay(100);
void loop() {
  //distance finding logic:
  long duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration/2) / 29.1;
  //"if" statement block for motor sensitivity:
  if(distance<RANGE_CLOSE&&distance>0){
    digitalWrite(motor,SENS_HIGH);
    delay(100);
    digitalWrite(motor,LOW);
  else if(distance<RANGE_MED&&distance>=RANGE_CLOSE){
    analogWrite(motor,SENS_MED);
    delay(100);
  else if(distance>=RANGE_MED&&distance<RANGE_FAR){
    analogWrite(motor,SENS_LOW);
    delay(100);
  else
The code you posted is Arduino code. Do you need the code to be ported to any other AVR micro ? If yes, mention AVR used, Crystal frequency and show circuit. I am attaching your Arduino code compiled for Arduino Uno R3.
It seems you need a code where motor of a robot is controlled based on distance measured using Ultrasonic sensor. If you are using Arduino boards then you can use NewPing library to get distance from US sensor.
  • build5758471438246879203.tmp.rar
thanks for replying. Actually yeah the vibrating motor is controlled by the uc based on distance sensed by the Sensor.
Also i am new to AVR microcontrollers. I have always worked in PIC's. Just let me know the codes which you sent me, can they be directly burnt in AVR microcontroller using a AVR Programmer? As i dont have Arduino board.
Regards
Hitesh
Yes, the hex file can be flashed in a stand alone AVR chip as long as the device and clock speed matches the one used at compile time.
It is very simple to get Arduino https://arduino.cc/en/Main/Software , you can either install it or just extract the folder and use it.
Having the compiler will help you experiment with the code without having to rely on others to compile it.
Hi. Thanks for replying.
I am facing an issue. I am currently working on project and my partner who actually writes codes for me is unavailable due to some reasons.
i already posted a code for AVR Attiny 85. I need the same Code for PIC16f876A UC. I have never worked on AVR's but just PIC's.
If anyone can help kindly reply. i Will share the project requirements..
Regards
Hitesh Joshi
As mentioned earlier Arduino and its libraries are open source. You can see the codes of NewPing library and port it with little changes to PIC. You can also use MPIDE with ChipKit Uno32 boards. They have PIC32 in that board and same NewPing library can be used with MPIDE. Chipkit boards work at 3.3V not 5V like Arduino but you get 32 bit controllers with lots of Program space and RAM.
