[SOLVED] Help needed with a VHDL code
YoussefHefny
Newbie level 2
Newbie level 2
hello there, here is my VHDL code :
"library ieee;
use ieee.std_logic_1164.all;
package andpackage is
compackage andpackage is
component and2 is
port (a, b: IN std_logic;
c: OUT std_logic);
end component and2;
end package andpackage;
Use work.andpackage.and2;
entity circuit2 is
port (a, b, x, y: IN std_logic;
d: OUT std_logic);
end entity circuit2;
architecture mixed of ciponent and2 is
c: OUT std_logic);
end component and2;
entity circuit2 is
d: OUT std_logic);
architecture mixed of circuit2 is
for gate: and2 use entity work.and2(and2);
signal c,z: std_logic;
begin
gate: and2 port map (a,b,c);
d <= c XOR z;
op: process (x,y) is
begin
z <= x OR y;
end process op;
end architecture mixed;"
the errors are :
"** Error: C:/Modeltech_pe_edu_10.2c/examples/circuit2.vhd(14): (vcom-1136) Unknown identifier "std_logic".
** Error: C:/Modeltech_pe_edu_10.2c/examples/circuit2.vhd(15): (vcom-1136) Unknown identifier "std_logic".
** Error: C:/Modeltech_pe_edu_10.2c/examples/circuit2.vhd(16): VHDL Compiler exiting"
Any help would be greatly appreciated, thanks in advance.
there are so many errors i even dont know where to start....
maybe grab some book about vhdl basic first
library ieee;
component and2 is
c: OUT std_logic);
end component and2;
library ieee;
entity circuit2 is
d: OUT std_logic);
begin
d <= c XOR z;
begin
z <= x OR y;
end process op;
Oh i am terribly sorry for this !! i copied multiple codes from different attempts in here. but i did read a bit about VHDL and i 've been doing well with other codes but i seem to have messed up big time with this one.
Thanks a lot for ur help !
<snip>
Perhaps you should read my reply to your question in comp.lang.vhdl. But to avoid the suspense, the following lines of code need to be placed both before the package definition (where you have them now) and also prior to the entity definition.
library ieee;
Kevin Jennings
