waqas5304
Member level 1
hi
i am doing a project in which i am using class AB audio amplifier to drive 8 ohm headphones.
my project has two similar circuit cards one is the main card and second is the standby card . both have same SSM2211. the power supply is used to switch between the main and standby cards.headphone for both cards is same.
what i am doing is that i am connecting the headphone parrallel to both ssm2211. when the main card is selected the power supply is provided only to the ssm2211 on main card and the ssm2211 on standby card is switched off .i think it should work but in reality the circuit gets short . any body has some solution .
the circuit diagram is attached for reference
i hope someone will give a good suggestion
waqas
waqas
