Help needed for convert Mikro c to Mikro C pro files
bauche
Junior Member level 1
Hi i'm newbie ....i found an code for can bus in mikroc work fine with mikroc 7.0.0.3... but i want to finish my project in microc pro
Does somebody help me to convert my .c file in .c pro???
i think my prob is about syntax an variable declaration...
Thanks...
This is the two files need to be converted in mikro c pro....
Thanks...
  • code can bus.rar
yes ....1 is collector node...the other one is display node....both of them are written in micro C
Can't compile the code without knowing the uCs used for Project. You have to mention the uCs used for both the programs and also Fosc. It is better if you zip and post the mikroC project files.
ok...the uCs is 18f2580 ...osc 20 mhz.....i'm on the road now but i can send you tonight the complete file with the microc project files
Thanks again
Regards
Here the files with project files in microc
Thanks again
  • test fonc.rar
It is giving some errors related to }. I copied and pasted the code. Try to type in the code and compile. I have fixed the CAN Bus Code.
  • can bus.rar
I'll check that this afternoon...
thanks again
Regards
