wangyuestc
I am working on the design of some subthreshold circuits based on TSMC 0.18 cmos process. But there is huge difference between the simulation and measured results.
I designed a regulator(power consumption=1uW) based on the subthreshold voltage reference proposed in the paper "A 300 nW, 15 ppm/ C, 20 ppm/V CMOS Voltage Reference Circuit Consisting of Subthreshold MOSFETs". Simulations show that Vout=1.8V@TT 1.6~2V@TT/ff/ss. However, the measured result of all chips is Vout=1.9~2V. I also simulate it with PCM DATA provided by the foundry, and I got the highest Vout=1.85V at worst case.
Another circuit is a low power oscillator(power consumption=1.4uW, f=1.92MHz). The measured clock frequency of most chips is only about 1.5MHz, while post-simulations predict the lowest freq is 1.7MHz at worst case.
Any help will be appreciated!!!
