are there low profile around 1mm hieght RF MEMs switches?
i tried to find some Rf switches but w/o sucsses in this forum recomended me RF relay but i couldn't find somehing that will be low profile , so now i try RF mems or pin diodes .
here is my specification for the Switch:
Please see below the RF analog ac switch specification:
- Operation frequencies: 0-20MHz
- SPST or SPDT
- Application: pass around 6W in Lo freq, block around 10mW in Hi freq
- Close/on state (when around 3Vdc applied to the switch controls):
Can pass 6Watt, 25Vac pp @ sub 0.5MHz
- Rds on: up to 200mOhm when switch is on state for minimal loss
- Open/off state (when no any power applied to the switch- normally off):
Can block 25Vac pp @ above 10MHz signal w isolation around 20dB
- Low profile: SMT part, preferably around 1mm height
- Target price: up to 2$ per unit
