Help me with Verilog code for implementing RAM
neefa
Member level 1
Member level 1
hi frnz,
I need to implement a RAM.which is designed in such a way that it takes 32 bit input with 32 registers and it should give the o/p in 4 parallel sequence 8 bits each In my code iam unable to get this .plzz help...iam attaching my code here.
module ram4(q,q1,q2,q3,q4, d, a, we, clk);
output [31:0] q;
output [7:0] q1;
output [7:0] q2;
output [7:0] q3;
output [7:0] q4;
input [31:0] d;
input [4:0] a;
input we;
input clk;
reg [31:0] read_add;
reg [31:0] mem [31744:0];
//reg [31:0]temp_reg;
always @(posedge clk) begin
if (we)
mem[a] <= d;
read_add <= a;
end
assign q = mem[read_add];
assign q1 = q[7:0];
assign q2 = q[15:8];
assign q3 = q[23:16];
assign q4 = q[31:24];
endmodule
thanks.
verilog query
Your code looks ok, except the sizes of 'read_add' (32 bits) and 'mem' (31745 words) are inconsistent with the size of 'a' (5 bits).
What kind of malfunction are you seeing?
The way you control the addresses, the module simply delays the input data by one clock. That's unexciting behavior.
Re: verilog query
I have corrected ur code!
output [31:0] q;
output [7:0] q1;
output [7:0] q2;
output [7:0] q3;
output [7:0] q4;
input [31:0] d;
input [4:0] a;
input we;
input clk;
reg [31:0] mem [0:31];
reg [31:0] q_tmp;
    q_tmp <= mem[a];
    if (we)
        mem[a] <= d;
end
assign q = q_tmp;
assign q1 = q_tmp[7:0];
assign q2 = q_tmp[15:8];
assign q3 = q_tmp[23:16];
assign q4 = q_tmp[31:24];
endmodule
    neefa
Re: verilog query
really i thank u for ur help...now my code is running correctly.my next step is to take these 4 outputs and to give to 4,2to 1 mux.for the other o/p to the muxi have to design similar ram.after muxing i will get 4 o/ps.
plz give me suggestions to start my code.
thanks.
Re: verilog query
hi,iam attaching my code here...
the problem is iam not getting the output in ISE simulator.
module buffer(Areal, Breal, Creal, Dreal, addr1,data1, we, clok, addr2,data2,sel);
output [7:0] Areal;
output [7:0] Breal;
output [7:0] Creal;
output [7:0] Dreal;
input [4:0] addr1;
input [31:0] data1;
input we;
input clok;
input [4:0] addr2;
input [31:0] data2;
//input we2;
//input clok2;
input sel;
wire [31:0]A;
wire [7:0]B;
wire [7:0]C;
wire [7:0]D;
wire [7:0]E;
wire [31:0]F;
wire [7:0]G;
wire [7:0]H;
wire [7:0]I;
wire [7:0]J;
//reg Areal,Breal,Creal,Dreal;
ram1 RAM1(A,B,C,D,E,addr1,data1,we,cl0k);
ram2 RAM2(F,G,H,I,J,addr2,data2,we,clok);
mux1 mymux1(Areal,B,E,sel);
mux2 mymux2(Breal,C,F,sel);
mux3 mymux3(Creal,D,G,sel);
mux4 mymux4(Dreal,E,H,sel);
endmodule
regards,
thx.
verilog query
Need more info to help you.
Can you show us your testbench, ram1 and ram2, mux1 through mux4, and whatever other modules they may use?
Also, what is your code suppose to do?
