s3034585
Full Member level 4
Help in matching
hi
i am designing layout for bias circuit. in that i have 4 pmos trans.. with a finger size of 10 each. there sournce are connected to a common source and the drain is connected to dif pins.
now i want to match theses transistor. the size is as follows
w = 50 u
l = 5u
fw =5 u
nf =10
count = 1
slice = 1.
as you can see the size and the no of fingers is 10 hence it will consume large
space if i keep them in series.
can any one tell me how to break them into more slices. because even though the fingers are 10 they are all in 1 slice hence cant be separted.
thanks in advance
tama
hi
w = 50 u
l = 5u
fw =5 u
nf =10
count = 1
slice = 1.
thanks in advance
tama
