[SOLVED] Help me with logic gates in a code for 4-bit counter
karthiga05
Member level 2
Member level 2
Hi guys. I've posted a few threads before regarding counters. This is still regarding a counter. my 4-bit counter. But im not sure if the part in RED is right.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity counter4 is
port(count:eek:ut std_logic_vector(3 downto 0);
clk:in std_logic;
reset:in std_logic);
end counter4;
architecture behav_counter4 of counter4 is
component ha port (a: in std_logic;
b: in std_logic;
sum: out std_logic;
c_out: out std_logic);
end component;
component fa port (a, b, cin : in std_logic;
sum, c_out : out std_logic);
end component;
signal ain,s,c:std_logic_vector(3 downto 0) :="0000";
signal bin:std_logic_vector(3 downto 0):="0001";
--configuration specification
for all:ha use entity work.ha(rtl);
for all:fa use entity work.fa(fa_behav);
begin
u1:ha port map(a => ain(0), b => bin(0), sum => s(0), c_out => c(0));
u2:fa port map(a => ain(1), b => bin(1), sum => s(1), cin => c(0), c_out => c(0));
u3:fa port map(a => ain(2), b => bin(2), sum => s(2), cin => c(1), c_out => c(1));
u4:fa port map(a => ain(3), b => bin(3), sum => s(3), cin => c(2), c_out => c(2));
counter:process(clk, reset) --process(sensitivity list)
begin
if reset'event and (reset = '1') then
s <= (others => '0');
elsif clk'event and (clk='1') then
ain <= c or ain;
s <= ain or bin;
c <= s and c;
end if;
end process;
count <= s;
end behav_counter4;
---------- Post added at 14:34 ---------- Previous post was at 14:30 ----------
it doesnt loop.
I am sorry to ask this. But why is there an adder for designing a counter?
I hope this would be it for the counter logic.
library ieee;
entity counter4 is
clk:in std_logic;
end counter4;
begin
signal count_sig : std_logic_vector (4 downto 0);
counter : process(clk, reset) --process(sensitivity list)
begin
count_sig <= (others => '0');
count_sig <= count_sig + 1;
end if;
end process;
count <= count_sig;
end behav_counter4;
its because im required to use this method. if im not, of course i would use the simpler one.
I think, it's wrong in two regards:
- it's not represneting an adder
- it creates a syntax error in the present design, because the signal s has multiple drivers.
Using an adder to build a counter is basically correct, also the behaviotal description count_sig <= count_sig + 1; simply infers an adder. In so far, you can expect that all (correct) counter implementations end up in the same gate level netlist.
