Help me with designing GMSK modulator in Matlab
peichinlim
Newbie level 6
Newbie level 6
GMSK modulator
hi,
Currently I'm working in my final year project. I need to design a GMSK modulator using MATLAB. Could anyone provide me any info?
Thank you.
:D
Re: GMSK modulator
peichinlim said:
hi,
Thank you.
:D
GMSK modulation is simular to MSK modulation except a gaussian impulse is required.
Hope that helps.
Regards.
Re: GMSK modulator
What component should be used to produce Gaussian impulse? because I'm creating .mdl file for GMSK modulator.
Re: GMSK modulator
You can use a lookup table to creat the Gausian impulse.
sixth
Re: GMSK modulator
Hello guys,
where can I find material and files on the analysis and design of Modulators using Matlab?
I'm just entering this topic.
Thanks in advance.
Lupin
Re: GMSK modulator
Hi Lupin,
if you want to design modulator in Matlab, you need to create a model file. All the components can be find in library browser.
Hi Sixth,
I never use a lookup table before. Can you show me the way?
Thanks
[/quote]
GMSK modulator
Hi Lupin
I hope you have the communication toolbox with your matlab instalation, searh in the help section how to use it.
To Peichimlin
you can find the equation of Gaussian pulses in https://mathworld.wolfram.com/GaussianFunction.html
if there is not that function already in matlab. Then generate a table with vales for x an y.
Sal
