Help me with calculating PIC USB system clock speed
urakhai911
Newbie level 6
Newbie level 6
Hey World,
I am working on a project in which I am using USB and CAN together. I am sending data to the PIC32MX795F512L on the Ethernet Starter Kit from the PC and sending data out through the CAN Bus.
I can get both modules to work individually but when placing the two together in the same program I face certain problems. I narrowed down the problem to the oscillator configuration. When the two programs are combined and I work with the Primary Oscillator (8 Mhz) with PLL the USB works and the CAN doesn't. When I use the internal FRC oscillator the CAN module works and the usb doesn't.
What I have decided to do is work with the Primary Oscillator with PLL and modify my CAN configuration to work with that system clock speed.
I need help with calculating my system clock speed. Here are the relevant configuration bits.
Code C - [expand]
8
9
10
11
12
13
14
#pragma config UPLLEN   = ON            // USB PLL Enabled
    #pragma config FPLLMUL  = MUL_20        // PLL Multiplier
    #pragma config UPLLIDIV = DIV_2         // USB PLL Input Divider
    #pragma config FPLLIDIV = DIV_2         // PLL Input Divider
    #pragma config FPLLODIV = DIV_1         // PLL Output Divider
    #pragma config FPBDIV   = DIV_1         // Peripheral Clock divisor
    #pragma config FWDTEN   = OFF           // Watchdog Timer
    #pragma config WDTPS    = PS1           // Watchdog Timer Postscale
    #pragma config FCKSM    = CSDCMD        // Clock Switching & Fail Safe Clock Monitor
    #pragma config OSCIOFNC = OFF           // CLKO Enable
    #pragma config POSCMOD  = HS            // Primary Oscillator
    #pragma config IESO     = OFF           // Internal/External Switch-over
    #pragma config FSOSCEN  = OFF           // Secondary Oscillator Enable
    #pragma config FNOSC    = PRIPLL        // Oscillator Selection
I have attached an image of the oscillator configuration for the PIC32MX.
Thanks!
Please tell me if I didn't explain the question properly.
hi i am having the same trouble u faced with pic32 ethernet starter kit. please let me know if u have got an answer to set the usb clock
LaTeX Commands Quick-Menu:
