tatnur
Newbie level 3
I implemented the above circuit in multisim and found the output before the transformer between collector and the ground..I used a 12V battery.. Instead of getting 12V peak to peak, i'm getting a very less value.. Only if i increase the resistances from 0.1R to approx 6k ohm, i'm able to get atleast 9V output.. What is the problem in the above circuit..? What is the function of the transistor bank in it..And what is the use of such a low resistance value when i'm able to get a considerable output for resistance in kilo ohms..?
