tahir4awan
Full Member level 4
I was looking for a programmer and find this
PIC Programmer and Experiment board projects support software winPic800,EpicWin,ProPIC18
and it confused me because it says
"This is a two-in-one PIC programmer and Experiment board for 40 pin PIC Micro devices.It easy to develop your program without insert/remove PIC micro.You just programming your code and then download to this board without any programmer .This board interface with parallel port.This board supports for PIC16F,PIC18F 40 pin devices"
First it says it is two in one PIC programmer but as you can see there is also a Parallel Port Programmer schematic is given.The development board has RS232 Port then how come both these boards connected simultaneously.
There is also a microcontroller on the development board and the site says board works without inserting/removing microcontroller.
This is so confusing can you explain me all these two boards ?
