Help me understand a peak detector diagram
zhaozenghui
Member level 2
I`m current doing research on the AGC .But the picture of this I can`t understand .Can you say something about it .
And how can I control S1,S2,when on and when off!
Vn ,Vp need inductor to get from Vin+,Vin- ??
Re: peak detector ,help
Can you tell us the frequency?
I have designed one which works with the frequency lower than 10MHz.
Added after 1 minutes:
It seems that A and B are inverters, isn't it?
This PD is too complex, why not use a simple one?
I don`t have another circuit!! it`s work at 46MHz
Can you provide some for me ,Thanks!!
Added after 3 minutes:
And I think A be inverter to B
It`s??
peak detector ,help
Is this one working as a rectifier?
In postive half of period, the current flows along the left side, but in negative half, current flows along the right side.
Do you have a published reference for this circuit ?
I don't see clearly why it has two stages of LPF.
