Nov 30, 2009 #1 A amila133 Member level 4 Joined Oct 13, 2009 Messages 72 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Location Sri Lanka Activity points 1,746 Hi, I used IR led and phototransistor pair. But it shows very small voltage difference for black and white surfaces. I do not have part nos of that components. pls tell me how should I increase the difference. Thanks..
Nov 30, 2009 #2 Y yego Full Member level 3 Joined Oct 28, 2004 Messages 161 Helped 18 Reputation 36 Reaction score 3 Trophy points 1,298 Location Middle of Nowhere Activity points 1,840 Why don't you post your schematic diagram ? It would be easier to resolve your problem. Guessing from thin air is rather ineffective in this case.
Nov 30, 2009 #3 mister_rf Advanced Member level 5 Joined Feb 26, 2008 Messages 1,870 Helped 1,040 Reputation 2,088 Reaction score 953 Trophy points 1,393 Location Romania Activity points 11,515 A possible solution: to use an IR filter in front of the optical sensor.
Dec 3, 2009 #4 G GetDeviceInfo Advanced Member level 4 Joined Mar 30, 2009 Messages 109 Helped 4 Reputation 8 Reaction score 6 Trophy points 1,298 Activity points 1,904 reflective type devices are typically lensed to focus thier outputs/inputs
Dec 3, 2009 #5 hameeds01 Advanced Member level 2 Joined Aug 23, 2005 Messages 599 Helped 75 Reputation 156 Reaction score 41 Trophy points 1,308 Location Islamabad Pakistan Activity points 4,540 hey man which technique u r Using?? Reflector or hole on the Disk ?? mostly this type of problem occurs due to the wrong angles of IR sensors.
