Benn Ng
Newbie level 6
hi,
sorry TS to jack the thread but i require some help. thanks
using arduino uno to generate 3 PWM signal with 120deg apart as attached . i would require to be fed into irs2336d mosfet driver. since irs2336 require 3high and 3 low signal . i need to split logic right after the arduino uno(3 pwm signal). how do i go about doing it.
as attached is the deadtime circuit that mobin design. can i use it to split the logic from 3 pwm to 3high and 3low by using the same setup that will be fed into irs2336d.
thanks
thanks
