Help me to calculate a RF mixer output/input power.
An_RF_Newbie
Member level 4
I have two RF generators with 2dBm output power. I have selected ADE-1+ from the mini-circuit. I need to know should I put any amplifier/attenuator for RF/LO inputs.
You question is not clear at all. Could you please elaborate more ?
This mixer needs +7dBm LO Power (min +4dBm), so you should amplify LO signal a bit. Other one is strong enough or you will need attenuate a little bit to prevent 1dB Compression Point that has not been mentioned.
+4dBm LO Power gives more appreciable result in some cases.
For any double balanced diode mixer (including ADE-1) is a good option to place a pad attenuator (at least 6dB) at LO input. This will improve the mixer flatness response over frequency, and also isolation vs frequency for LO port. But this option needs to increase the level of the LO by 6dB, and may need an amplifier on the LO path to do this.
