Help
Advanced Member level 2
I'm using rechargeable coin battery for RTC. At first this new battery comes with 4Volt but on top of battery they mark it as 3.6V. The RTC Vb requited is 3V/27uA but the new battery given extra 1V.
In between the battery and RTC Vb i tried put a higher 100K resister to reduce down the current flow. With this method i able to reduce down the voltage at Vb but still can't reduce down to 3V for RTC required. Finally i try to use a 3V zener diode to regulate down the voltage but the battery life can't be last longer. The circuit shown below:
Is there any better suggestion?
Thank you,..
Thank you,..
