Help me plot the gm of OTA versus the differential input using Spectre
safwatonline
EGYPT
hello,
i want to plot the gm of OTA ,versus the diffrential input , i am using spectre , can any one help me?
i attached a picture of what i want to draw taken from a papper.
thnx
Re: gm
I guess your question is: Plot GM with ID or something like that....
If so, then check for a Calculator tool within Cadence. Google it, you should find some kind of tutorials..
I think there has been many discussions about Calculator in this webforum. Search it.
Srivatsan
Re: gm
Srivatsan
well ,,can you upload some of these tutorials??
Re: gm
make dc analysis with the differential input as a variable. then after running the analysis, u can draw the gm of the input pair from the result browser window
Re: gm
Check these attachments.. The credit for the tutorial goes to the concerned author.
I hope they are useful.
Srivats
  • cadence_manual_1857.pdf
    safwatonline
Re: gm
Provides a good overview of Cadenec suite of tools;what does it mean to this question?
gm
hello,
thnx for the replies,
i need to make this plot at a certain i/p freuqncy ,(i.e. not DC analysis).
any suggestions.
Re: gm
Very simple. Do AC sweep at certain frequency.
But there is some trick. Apply AC/DC source with to inputs of OTA though voltage controlled voltage sources (vcvs) with gain +0.5 and -0.5. DC voltage of this source is differential voltage between inputs (VDM). So u can do AC sweep on VDM variable at certain frequency and plot Gm = Iout_ac/Vin_ac vs. VDM.
I attach testbench picture for opamp. I use verilog-a negative feedback to eliminate offset voltage of opamp. For OTA i think u should to short output of OTA on certain potential, and eleminate offset of OTA under zero output current condition. I hope u can do it by yourself.
Look reference link for good tutorial:
