huahuagood
khanpur chown
hi,all,
i have installed ic610 .
i want use the verilog-xl,so i should install the IUS.i dont know whether the IUS58 can be installed by using the ic610's InstallScape.
when it asked if i had installed the InstallScape ,i selected y.in fact,if i select n,it will exit. then the InstallScape'GUI appeared, after selected what to install,it begin install.But without 10 second ,the error appear:
in the terminal,they are:
and,what should i do to go on now?
Thank you all.
Best wishes!!
huahuagood.
Added after 1 hours 38 minutes:
ai,
How pathetic!
What foolish mistakes i have made!To solved it Just change to the substitute user:
i had use chown xsky eda/ius58,so i thought it was unnecessary to change to the substitute user.but this isu58 is not that ius58 yet.
thank you all.
hi,all,
[xsky@localhost ~]$ uname -a
Linux localhost.localdomain 2.6.18-8.el5 #1 SMP Fri Jan 26 14:15:21 EST 2007 i686 athlon i386 GNU/Linux
[xsky@localhost ~]$ tar --version
tar (GNU tar) 1.12
Copyright (C) 1988, 92, 93, 94, 95, 96, 97 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Written by John Gilmore and Jay Fenlason.
[xsky@localhost ~]$ compress -V
Compress version: (N)compress 4.2.4, compiled: Tue Oct 5 05:17:07 EDT 2004
Compile options:
FAST, DIRENT,
REGISTERS=20 IBUFSIZ=1024, OBUFSIZ=1024, BITS=16
Author version 4.2 (Speed improvement & source cleanup):
Peter Jannesen (peter@ncs.nl)
Author version 4.1 (Added recursive directory compress):
Dave Mack (csu@alembic.acs.com)
Authors version 4.0 (World release in 1985):
Spencer W. Thomas, Jim McKie, Steve Davies,
Ken Turkowski, James A. Woods, Joe Orost
[xsky@localhost ~]$
tar xvf Base_IUS58_lnx86_1of3.tar
tar xvf Base_IUS58_lnx86_2of3.tar
tar xvf Base_IUS58_lnx86_3of3.tar
cd IUS58_lnx86.Base/CDROM1/
./SETUP.SH
Tue May 19 12:39:38 CST 2009
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.56) for mpsJava06.01
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.56
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.26) for cdsdocVerity02.20 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.26
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.14) for cdsCmonJava05.01 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.14
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.22) for cdsdocIndexer02.20 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.22
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.36) for qsrDocI05.81
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.36
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.17) for cdsJava14.26 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.17
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.39) for smTool03.00 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.39
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.57) for mpsLib06.01 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.57
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.16) for cdsCommon64b05.01 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.16
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.10) for OnHold product 01.00
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.10
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.25) for cdsdocUtils02.20
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.25
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.31) for hardmodDocR05.81
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.31
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.35) for mps06.01 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.35
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.23) for cdsdocSearch02.20
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.23
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.60) for pli05.81 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.60
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.49) for simvision05.81 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.49
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.42) for cir64b05.01 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.42
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.21) for cdsdocIndex58.00
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.21
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.30) for confData05.81
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.30
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.50) for simvision64b05.81 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.50
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.55) for lbsJava06.01
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.55
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.52) for cdsTk08.06 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.52
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.12) for SftShrTools10.10 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.12
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.53) for gccLibRHEL2103.23 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.53
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.18) for cdsPerl50.41 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.18
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.62) for pliwiz05.81 lnx86
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.62
Error: could not unpack file (/opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.24) for cdsdocSupport02.20
Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM1/IMAGES.DIR/FS.24
at com.khanpur.installerng.CDInstallThread.installPComps(CDInstallThread.java:288)
at com.khanpur.installerng.CDInstallThread.processMedia(CDInstallThread.java:249)
at com.khanpur.installerng.CDInstallThread.run(CDInstallThread.java:142)
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.31
With the custom file extractor install/tmp/sltar.sh
at com.khanpur.util.zip.CustomService.unpack(CustomService.java:295)
at com.khanpur.installerng.UnpackManager.installPhysicalComponent(UnpackManager.java:94)
at com.khanpur.installerng.CDInstallThread.installPC(CDInstallThread.java:492)
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.18
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.34
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.20
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.7
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.16
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.51
com.khanpur.util.exception.KPException: Could not unpack: /opt/temp/IUS58_lnx86.Base/CDROM3/IMAGES.DIR/FS.33
Thank you all.
Best wishes!!
huahuagood.
ai,
How pathetic!
su
thank you all.
