Help me out with layout of 8:1 pnp bipolar pair
pugongying
Member level 3
Member level 3
I want to layout the 8:1 pnp bipolar pair,and arrange them in 3X3 square,since all of the bipolars' collector and base are connnected to ground,I use metal 1 to connect them all,and I use metal 2 to connect the emitter of the outer 8 bipolar in a circle,also use metal2 to connect the central bipolar.
I wonder whether I can use metal 1 in four directions OR I should avoid parallel layout of metal 1 and metal 2?
Thanks very much!
Re: layout of bandgap
I'm not sure which is better.
But in my chip, I use metal 1 to connect GND and metal 2 connect the emitter the tapout reslut is ok.
layout of bandgap
Don't have cycle for 8 outer pnps. Keep metal2 for 8 outer pnps and metal2 for inter pnp paralled for connections so that the invironment will be similar.
Please study the picture i uploaded. Do not worry about the metal layer, it is not so sensitive.
[/img]
layout of bandgap
smilondon,
This is good bjt example, but what I feel, If We can use M3, then connect all outer emitter with M2( Make a ring) & take center emitter connection with M3. This will give more symmetrical routing give good centriode matching. Even you can observe the improved result with simulation.
You make one like what you see in figure 2 on this site
layout of bandgap
Smilodon, I am a new guy in analog design. So what u provide here is great, thanks.
