the value modulator bpsk
nirav said:
I don't understood why I need to store magnitude of sine wave in Look-up-table.
Thanks,
Nirav
The reason you need to store the magnitude of the sine wave in a look-up-table is because it is one of the easier ways to generate it. So, you'll need to create a table with sine wave values. Each of them will be indexed. Then you'll need a counter to loop through them, each time asking to return a value of a sine wave based on counter index. Once you have the value returned by your new sine wave generator function (your table in other words), you can directly output it to a pin of FPGA. If you probe it with oscilloscope, you'll see the sine wave. The frequency will depend on the counter speed.
Now, if you want to create a BPSK modulator, you'll need to have 180 degree shifted versions of this wave. Since BPSK is similar to BAM, 180 degree shift means just multiplying by -1, or simply outputting the negative value that is returned from your table. So, If you have one bit per symbol as in real BPSK, create an IF statement in VHDL and if your data is +1, output the whole wave period from a table as is. If it is -1, then just output its inverted value!
I saw a website somewhere which had a Perl based VHDL code generator for sinewave lookup table. You can specify a number of sampling points and it will give you the whole table you can shift through.
This should help
Added after 3 minutes:
To optimize the sine wave storage space, you can save just 1/4 of the period and create a little algorithm to increase/decrease the counter and flip the output accordingly depending at which part of T you are at.
For example,
2nd quarter for sin wave will be reducing the counter, so you are outputting values from max to min.
-for 3rd - you are going into negative, so you are increasing your counter, but outputting the negative value.
etc..
