Help me make a toy tank with a remote control
Sadegh.j
Advanced Member level 3
hey
Have to make a toy with a remote control. The tank has 4 wheels which moves forward, backward, right and left. The barrel should do the same. To fire, a sound IC should make a noise, the remote control has 9 button, one fire, 4 direction of the movement of tank and 4 determines the direction of the movement of the barrel.
Any suggestion??
Re: Toy tank
hi
AVR microcontroller contains already made functions in basic for sound playing and remote control
the directions are simply by reversing the polarity of motor
Re: Toy tank
Sadegh.j said:
hey
Any suggestion??
Do you want a wired or wireless remote control?
To control the motor direction, you can use L293D, search the board for its uses or the internet for its datasheet.
For the sound, a pic micro can always be used to create the sound, you can use the timers.
Re: Toy tank
Hey
The control is wireless. Can PIC produce any sound. It should sound like a tank firing, (Or some thing similar to it)
Thanks
Re: Toy tank
for the wheels: use L298 or L293 and two DC motors
for the barrel, use: ULN2003 as a stepper motor driver, of course you need a small stepper motor for this
for the sound IC: google it
all datasheets are most available at: www.datasheets.org.uk
PIC doesn't produce a firing sound, though you may DAC to it
but, I suggest to have a sound gen IC for this
for the PIC: it's your choice, but PIC16F877 would do
Added after 2 minutes:
Oh, almost forgot, FSK radio is better for wireless control
Re: Toy tank
u can use pic r either 89c51 for this but the thing is the wireless interface just finalise it first then u can use a suitable micro controller and the sound generator
