Help me fix my Assembly code for display 'A' on 16x2 LCD
smiles
hi ! I am quite new to assembly coding (using Pic16F877)
here is my program for display 'A' character on LCD screen and it wrong (simulate using Proteus)
	list		p=16f877a	; list directive to define processor
	#include	<p16f877a.inc>	; processor specific variable definitions
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _RC_OSC & _WRT_OFF & _LVP_ON & _CPD_OFF
	org		0x0000
	goto 	Main
	org		0x0005
Main
	banksel	TRISB
	movlw	00h
	movwf	TRISB		;Set all PORTB pins to output
	banksel	TRISA
	bsf		ADCON1,1	;Port A is digital I/O
	bsf		ADCON1,2	;...
	movlw	01h
	movwf	TRISA		;pin 0 is input, the rest is output
	banksel	PORTA
Main1
	clrf	PORTB
	bsf		PORTA,2		;RS pin on
	bsf		PORTA,4		;E pin on
	bcf		PORTA,3		;R/W pin off
;	banksel	PORTB
	movlw	41h
	movwf	PORTB		;"A" character
	bcf		PORTA,4		;E pin off
	bcf		PORTA,2		;RS pin off
	bsf		PORTA,3		;R/W pin on
	goto	Main1
	END
Here is the diagram
and the write process diagram of LCD (LM018L) is here
https://img2.freeimagehosting.net/uploads/3d2122c70f.jpg
Could you tell me what wrong with my code, thanks so much !
Turbokeu
Junior Member level 1
16x2lcd+test+program
RA4 port is on most PICs (if not all) of open collector type. This means you need a pullup resistor (ex. 10K) to +5V.
Also I don't like the way you connect your push button to a port. Here also you should use a pullup or pulldown resistor and act accordingly in software.
See also here:
CD :)
smiles
lcd character display 16x2
Thanks, but I just do simply with my test program, seem that you very familiar with Proteus, do you know the meaning of yellow signal at pins when simulating ?
Thanks !!!
Turbokeu
proteus 16x2 lcd test
Never had a 'yellow signal' with Proteus but I suppose this is an undefined level: not '0' (GND) and not '1' (+5V).
Put the pullup/pulldown resistors as I advised.
CD :)
smiles
Re: 'A' on 16x2 LCD
I had followed your advice !!!
Thanks !!! :)
