Help me fix coding for PIC16C745 which will turn on/off a LED light
christina86
Newbie level 5
Newbie level 5
Dear Friends,
I am using the MPLab 7.2 to write an assembly language using PIC16C745 to turn ON & OFF the Led Light using the push button.
I have successfully burn the Code inside the PIC16C 745 but when i apply the 5V voltage .it failed to turn on.
Here is my code :
list p=16c745 ; list directive to define processor
#include <p16c745.inc> ; processor specific variable definitions
__CONFIG _H4_OSC&_WDT_OFF&_PWRTE_OFF&_CP_OFF
org 0X00000030
Start
bsf STATUS,RP0 ; select bank1
movlw b'00000110' ; Set pins PORTB 1,2 as Input and the rest as "output"
movwf TRISB ;
bcf STATUS, RP0 ; go back to Bank 0
ON
btfsc PORTB,1 ; has S1 been press? (Normally high,goes low when pressed.)
goto ON ; No, go back check again
bsf PORTB,0
OFF
btfsc PORTB,2 ; Has key been press? (Normally high, goes low when pressed.)
goto OFF ; No, check again
bcf PORTB,0
goto Start
end ; directive indicates end of code
Can you help me to check where did i go wrong and how the correct way should be ?
Re: Help for 16C745
ur code looks strange...
here is program for ON/OFF of the LED using Interrupts on PIC16F84A, i think you can easily transfer this program to your chip:
; File: RB0Int.ASM
; Date: April 22, 2006
; Author: Julio Sanchez
; Processor: 16F84A
; Description:
; Program to test interrupt on port RB0
; A pushbutton switch is connected to port RB0.
; The pushbutton toggles a LED on port-B, line 7
; setup and configuration
processor 16f84A
include <p16f84A.inc>
__config _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
; variables in PIC RAM
cblock 0x0d       ; Start of block
count2               ; ISR counter
old_w                 ; Context saving
old_STATUS
Delay1
count1
endc
; ********** PROGRAM START **********
org 0                   ; Program start at address 0
goto main
; INTERRUPT HANDLER
org 0x04
goto IntServ
; MAIN PROGRAM
main:
bsf      STATUS,RP0         ; Select Bank1
bcf      OPTION_REG,INTEDG   ; Set interrupt on falling edge
                     ; by clearing INTEDG bit of OPTION_REG
movlw    b'00000001'         ; PORTB bit 0
movwf   TRISB            ; is Input, all other bits are Output
bcf      STATUS,RP0          ; Go back to Bank0
clrf    PORTB             ; Clear PORTB
;bsf    PORTB,0          ; set PORTB bit 0
                     ; SETUP INTERRUPTS
bcf INTCON,INTF          ; Clear external interrupt flag (INTF = bit 1)
bsf INTCON,GIE             ; Enable global interrupts (GIE = bit 7)
bsf INTCON,INTE          ; Enable RB0 interrupt (INTE = bit 4)
; flash led
Loop:
nop
nop
nop
goto   Loop
;clrf   PORTB
; Interrupt Service Routine
IntServ:               ; First test if source is an RB0 interrupt
btfss INTCON,INTF          ; INTF flag is RB0 interrupt
goto notRB0             ; Go if not RB0 origin
                     ; Save context
movwf old_w             ; Save w register
swapf STATUS,w            ; STATUS to w
movwf old_STATUS          ; Save STATUS
                     ; Make sure that interrupt occurred on the falling edge
                     ; of the signal. If not, abort handler
btfsc PORTB,0             ; Is bit set?
goto exitISR             ; Go if clear
; interrupt action
;clrf   PORTB
movlw 10                ; Number of repetitions
movwf count2             ; To counter
wait:                  ; Check to see that port-B bit 0 is still 0
                     ; If not, wait until it changes
goto exitISR             ; Go if bit not 0
                     ; At this point RB0 bit is clear
decfsz count2,f          ; Count this iteration
goto wait                ; Continue if not zero
                     ; Interrupt action consists of toggling bit 2 of
                     ; port-B to turn LED on and off
; ACTION!!!!
movlw b'10000000'          ; Xoring with a 1-bit produces
                  ; the complement
xorwf   PORTB,1             ; Complement bit 2, port-B
; exit ISR
exitISR:               ; Restore context
swapf old_STATUS,w          ; Saved STATUS to w
swapf old_w,f             ; Swap file register in itself
swapf old_w,w             ; re-swap back to w
notRB0:                  ; Reset,interrupt
bcf INTCON,INTF          ; Clear INTCON bit 1
retfie
delay:
movlw 4
movwf count1 ; Store value in counter
repeat:
decfsz count1,f ; Decrement counter
goto repeat ; Continue if not 0
return
end
Re: Help for 16C745
hi,
Thank you so much to post the sample code. Your code only used one switch is it ?
May i know how to schematic be like. May you help me to ponit out where did i go wrong in my code.
Thank you
Help for 16C745
it is using active Low logic, take a value of 4.7K for the resistor.
well...ur code is mess, and it doesnt use interrupts, so forget it :D
use interrupts for such things :)
