Help me!(Design of 10 bit DAC)
liccAMS
Junior Member level 1
hello friends
we now should design of 10 bit DAC with 2.5v process.Power and noise are the most important things we need conside.INL, DNL under 1 LSB
If we use the R-2R structure,the mismatch and power may limit us to attach the requirement.
Can you give me some advices about what architecture should I use.
hoping your replay
thanks in advace
sunking
Advanced Member level 3
it depond on your speed, power.
many architecture you can use.
voltage weighting, current weighting, charge weighting, single slope, dural slope and so on
paulux
Full Member level 1
What is the speed/application of DAC?
Hi sunking,
Given the requirement of 10bit DAC with less than 1LSB in INL & DNL,
what are the factors determining the architecture of DAC?
could you recommend some references/papers for the techniques you described?
zkkbmy
Newbie level 6
Newbie level 6
I think the book-CMOS DATA CONVERTERS FOR COMMUNICATIONS can help you! you download this book in edaboard. hope it can help you.
liccAMS
hi paulux:
the speed is about 1MSPS
used for AFC, APC of analog base band
can anyone help me getting some related documents?thnx!
