Help me design a combinational circuit hat compares two 4-bit numbers
fm_com_28
Full Member level 1
Fayoum, Egypt
Dear,
I want to design a combinational circuit hat compares two 4-bit numbers to check if they are equal. The circuit output is equal to 1 if the two numbers are equal and 0 otherwise.
Comparator
Dear,
u can use 4 XOR gate and combine all the four output of xor gates in a 4 input NOR gate and the output of this NOR gate is the required output.
Added after 55 seconds:
IF u need Schematic we can post that also but first try your self.....
    fm_com_28
Re: Comparator
Hi fm_com_28,
You could use a 74(XX)85 circuit, it's a 4 bit magnitude comparator,
no need to design a custom circuit.
Just connect your two four bit numbers to A0 . . . A3 and B0 . . .B3. Don't
forget to make the "A smaller than B" and the "A larger than B" cascade
inputs logical "0" and the "A equals B" cascade input logical "1".
There are three outputs: A greater than B, A = B and A smaller than B.
on1aag.
Re: Comparator
Yes nikhilele i need the schematic plase.I also need the software you use to draw logic schematics.
Re: Comparator
hi hi,
u may also make use of this folowing diagram:
the software... u may use altera quartus II (free web edition software), u may download the software through the altera website as:
https://www.altera.com/products/software/products/quartus2web/sof-quarwebmain.html
i hope these may help u...
regards,
hippoo
