kjemmo
Newbie level 1
Hi
This is my first post.
I am new to DIY electronics and need to learn a lot. I hope that you will all be kind enough to answer some newbie questions.
I am currently playing around with some solar cells and TEG projects for charging my iPhone when I go hiking.
I have a very basic multimeter that can measure voltage, but I need an ampere meter that can give me current measurements with a least 10ma accuracy.
I bought a cheap clamp ampere meter on ebay.com but it seems that it can not measure the low current and voltage that I am playing with.
The specs are as follows:
Range AC20A Resolution 10mA Accuracy ?2.5%+10d)
Range AC200A Resolution 100MA Accuracy ?2.5%+10d)
Range AC600A Resolution 1A Accuracy ?2.5%+10d)
Question #1:
Do I need to find a clamp ampere meter with a lower range like: Range AC2A Resolution 1mA Accuracy
Question #2:
Should I look for a different type of meter like this one: **broken link removed**?
Question #3:
Or are there better options that do not even know about?
The lowest voltage and current I will need to measure will be ~0.5V & 100ma.
All suggestions are most welcome.
Thanks
Question #1:
Question #2:
Question #3:
Thanks
