hbaocr
Full Member level 4
lpc2148 adc example
I have just studied ARM7 and using LPC2148. I have met some problems
about it. That I have done following the direction about ADC cell on
user menu LPC214x for writing keil C code base on example on site
keilC.but it doesn't do as I want. The result of conversation alway
zero.Why it is? the result only display on AD1GDR but the result of it on its reg AD1DDR0 alway 0. why ?????
plZ send me some C code to solve that problem.
here my code
and project
here my code
and project
/* Examples Program For "CP-JR ARM7 USB-LPC2148" */
/* Target MCU : Philips ARM7-LPC2148 */
/* : X-TAL : 12.00 MHz */
/* : Run Speed 60.00 MHz (With PLL) */
/* : PLL Setup = M(5),P(2) */
/* : VPB Clock = CPU Clock = 60.00 MHz */
/* Keil Editor : uVision3 V3.03a */
/* Compiler : Keil CARM V2.50a */
/* Create By : Eakachai Makarn ([url]WWW.ETT.CO.TH[/url]) */
/* Last Update : 17/May/2006 */
/* Function : Example Display ADC8(P0.6)-> UART0 */
// Used GPIO0.6 = AIN8 (ADC8) Measure Voltage
// Display Result on UART0(9600,N,8,1)
#include "LPC214x.H" // LPC2148 MPU Register
#include <stdio.h> // For Used Function printf
/* pototype section */
void init_serial0 (void); // Initil UART-0
int putchar (int ch); // Put Char to UART-0
int getchar (void); // Get Char From Uart-0
void delay(unsigned long int); // Delay Time Function
unsigned int val; // ADC Result (HEX)
float volt; // ADC Result Volt
int main(void)
PCONP|=1<<20;//set PDA1
init_serial0(); // Initial UART0 = 9600,N,8,1
//Initial ADC8 (GPIO-0.6) By Set PINSEL0[13:12=11]
// xxxx xxxx xxxx xxxx xx11 xxxx xxxx xxxx
PINSEL0 |= 0x00003000; // Select ADC8 Pin Connect P0.6
// Initial ADC8 (ADCR=0x01210601)
AD1CR &= 0x00000000; // Clear All Bit Control
AD1CR |= 0x00000001; // Select ADC = AIN8
AD1CR |= 0x00000600; // ADC Clock = VBP(PCLK) / 7
AD1CR |= 0x00010000; // Busrt = 1 = Conversion Continue
AD1CR &= 0xFFF1FFFF; // CLKS = 000 = 10Bit : 11 Cycle Clock Conversion
AD1CR |= 0x00200000; // PDN = 1 = Active ADC Module
AD1CR &= 0xFF3FFFFF; // TEST[1:0] = 00 = Normal Mode
AD1CR &= 0xF7FFFFFF; // EDGE = 0 = Conversion on Falling Edge
AD1CR |= 0x01000000; // START = 001 = Start Conversion Now
// Start Test Read ADC8 and Display on UART0 //
while(1) // Loop Continue
do // Loop Read ADC1.1(ADC8)
val = AD1DR0; // Read A/D Data Register
while ((val & 0x80000000) == 0); // Wait ADC Conversion Complete .error
//loop forever at this row on simulitor
val = (val >> 6) & 0x03FF; // Shift ADC Result to Integer
volt = val * 3.3 / 1023.0; // Volt = ADC Result x [3.3V / 1024]
printf("\rADC8 Result = %1.1f Volt.",volt); // Display 3-Digit Result(0-3.3V)
delay(10000);
/* Initial UART0 = 9600,N,8,1 */
/* VPB(pclk) = 60.00 MHz */
PINSEL0 &= 0xFFFFFFF0; // Reset P0.0,P0.1 Pin Config
PINSEL0 |= 0x00000001; // Select P0.0 = TxD(UART0)
PINSEL0 |= 0x00000004; // Select P0.1 = RxD(UART0)
U0LCR &= 0xFC; // Reset Word Select(1:0)
U0LCR |= 0x03; // Data Bit = 8 Bit
U0LCR &= 0xFB; // Stop Bit = 1 Bit
U0LCR &= 0xF7; // Parity = Disable
U0LCR &= 0xBF; // Disable Break Control
U0LCR |= 0x80; // Enable Programming of Divisor Latches
// U0DLM:U0DLL = 60.00 MHz / [16 x Baud]
// = 60.00 MHz / [16 x 9600]
// = 390.6 = 391 = 0187H
U0DLM = 0x01; // Program Divisor Latch(391) for 9600 Baud
U0DLL = 0x87;
U0LCR &= 0x7F; // Disable Programming of Divisor Latches
U0FCR |= 0x01; // FIF0 Enable
U0FCR |= 0x02; // RX FIFO Reset
U0FCR |= 0x04; // TX FIFO Reset
U0FCR &= 0x3F;
/* Write Character To UART0 */
if (ch == '\n')
while (!(U0LSR & 0x20)); // Wait TXD Buffer Empty
U0THR = 0x0D; // Write CR
return (U0THR = ch); // Write Character
/* Read Character From UART0 */
int getchar (void)
while (!(U0LSR & 0x01)); // Wait RXD Receive Data Ready
return (U0RBR); // Get Receice Data & Return
/* Delay Time Function */
/* 1-4294967296 */
void delay(unsigned long int count1)
while(count1 > 0) {count1--;} // Loop Decrease Counter
