help me, about ldv installation?
quan228228
Full Member level 4
Full Member level 4
When i install ldv50 under linux, do i must install software from cdrom?
Thanks!
tsinghua
Full Member level 4
Full Member level 4
No necessary. If you have the tar files, you can simply untar them. And then in the CD1 directory, you will find a script named setup.sh. Just run it with "./setup.sh".
quan228228
Full Member level 4
Full Member level 4
yes. i have untar the files, and find setup.sh in CD1 directory. But i still can't install ldv50. The following are the installation process. Pls read it and teach me, Thanks !
Steps:
A: Main Menu
1) load available products
2) list installed products
3).......
Type your choice: 1 (I select 1st option)
B: CD#1 of the media ste being used is required
You must now identify where the cd_rom is mounted
1) local (mounted to this machine)
2) Remote (mounted to another machine)
Type your choice: 1 ( I select 1st option)
C: Specify the cd_rom mount point
1) cd_rom
2) other
Type your choice: 2 (I select 2nd option)
and then enter the dirctory of mount point: /tools/ldv50/cd1
The return infor is " image not found
unable to read media /tools/ldv50/cd1".
So, here, i cant continute install my software. My installation file is in dirctory "/tools/ldv50/cd1 and /tools/ldv50/cd2".
tsinghua,
Could you give me some advice? Thank you!
David
Any another guy's suggestions are welcome. Thank you all!
Shurik
Full Member level 3
Full Member level 3
Hi!
I offer next =>
1. Create directory (Ex. /home/tmp_soft)
2. Untar all CD in this directory
3. Create directory where You will been LDV installs (Ex. /home/LDV5.0)
4. Go in directory where untar CD (Ex. /home/tmp_soft/CDROM1)
5. Start ./SETUP.SH in /home/tmp_soft/CDROM1
Try ...
Best regards!
    quan228228
quan228228
Full Member level 4
Full Member level 4
Shurik said:
Hi!
I offer next =>
Try ...
Best regards!
Yes, i installed ldv50 like you said, but in 3rd step, ask me to Specify the cd_rom mount point , how should i do next?
Thanks for your advice!
Shurik
Full Member level 3
Full Member level 3
Hi
Necessary be where exist SETUP.SH !!!!
installer will offer self the mount point
Is it not offer?
    quan228228
quan228228
Full Member level 4
Full Member level 4
Shurik said:
Hi
Is it not offer?
Installer offers the mount point. But i want to install the software from hardware instead of CD_ROM. Can i do like this ?
Very very thank you!
Shurik
Full Member level 3
Full Member level 3
Hi.
Yes you are !!
You may look this documentation.
Best regards !
    quan228228
quan228228
Full Member level 4
Full Member level 4
Shurik said:
Hi.
Yes you are !!
Best regards !
I am very thankful to you. But in third step, i type the choice: 2 (other instead of cd_rom) and then enter the dirctory of mount point, but i can't find the similar directory like pdf file shows(/tmp/IC5141/.....).
How could i know my computer's cd_rom mount point?
THANK YOU VERY MUCH!
David
Shurik
Full Member level 3
Full Member level 3
Hi quan228228 !!
In PDF file have the example show !
I can advise =>
1. You will copy your CDs on HD
CD1 into directory CDROM1
CD2 into directory CDROM2
2. Go into CDROM1
3. Installation start !
Try !!!
Added after 3 minutes:
Write the command
ls -laR /tools/ldv50/* > ls.txt
And send this file pls!
    quan228228
quan228228
Full Member level 4
Full Member level 4
Shurik said:
Hi quan228228 !!
I can advise =>
2. Go into CDROM1
Try !!!
Write the command
I still cant. :cry:
Thank you taking so much time help me.
The attached file "ls.txt" shows files in installation directory "/tools/ldv50".
The attached file "cdrom1.txt" shows files of CD1 of software , "cdrom2.txt" shows files of CD2 of software.
David
Shurik
Full Member level 3
Full Member level 3
I have seen your listing !! And I think the best there is change small letter
to uppercase letter !!
Ex.
fs.0 -> FS.0
TRY !!
When you will be install LDV, clear the directory where it will be installed.
Best regards !
Added after 4 minutes:
P.S.
Linux sensing by register of letters
    quan228228
quan228228
Full Member level 4
Full Member level 4
Shurik said:
P.S.
yeah, :D:D:D you are right. I completed installation.
Thank you very very much. You are so nice, enthusiastic, good guy.
"Linux sensing by register of letters" is quitely right. At the beginning, i always change the uppercase letter to lowercase in setup.sh file, because there are less change to do than modifiying fs.* to FS.*.
Ok, i understand, linux is sensing by register of letters. This is the cause why i cant install the IC50 early.
:D Thank you very much. you are something.
David
51cfpl
Newbie level 3
Newbie level 3
I always make files into iso files, then mount them in /mnt
