Help: LM35 & ADC0831 interfacing with 8051
hashim5003
Junior Member level 2
I am new to c language. I am trying to use LM35 for temprature reading with 8051. I need to know that how to receive serial data from ADC0831 with 8051 and then send it to LCD? I have wrote some code but can't do the receiving part? Should I create an array to save the bytes received from adc or something else?
What specific variant of the 8051 are you utilizing?
What programming language are you using to write the code?
Have you written the MICROWIRE interface routines?
BigDog
I'm using at89s52 and using c language.
Don't know about MICROWIRE interface routines.
The ADC0831 utilizes a three wire interface, MICROWIRE, similar to SPI.
Checkout Atmel AT89S52 product page under documents:
Documents for AT89S52
Program Examples for 8051 SPI
Code Examples for 8051 SPI
You should be able to adapt the above SPI routines for use with the MICROWIRE device.
You can also search for 8051/AT89S52 SPI routines and tutorials here in the forum and Google it as well.
BigDog
Typically, at least in your case, the microcontroller, AT89S52, is the master and the peripheral device, ADC0831, is the slave.
As both MICROWIRE and SPI allow for more than one peripheral device to be connected to the data input and output line at one time, the Slave Select (SS) or Chip Select (CS) line is simply a GPIO line which selects the particular peripheral device with which to communicate.
Serial Protocols Compared
Introduction to Serial Peripheral Interface
BigDog
BigDog
I read your links, quiet helpful. but still I don't know where to start write program. Should I create an array to store data received from output pin or do something else?
The ADC0831 has a resolution of 8-bits, range of 0 to 255, therefore you can simply store the conversion in an unsigned char or an array of unsigned char if you wish to store more than one conversion and calculate the average of the set.
I would first recommend supplying the ADC with a stable voltage of known value and then develop your SPI/MICROWIRE read/write/control routines, using the LCD to display the resulting 8-bit value.
Once you'll succeed in transferring and storing the conversion value from the ADC0831 to the AT89S52, you can then connect the LM35 and work on the conversion routines.
BigDog
BigDog
bigdogguru
I have worked on the code. Plz check if it is correct or not?
Edit: It's not working. What's wrong in it?
#include<reg51.h>
void delay (int);
void lcd_init (void);
void lcd_cmd (char);
void lcd_data (char);
//char read_data (char);
sbit RS = P1^0;
sbit EN = P1^1;
sbit CS = P1^2;
sbit CK = P1^3;
sbit DO = P1^4;
char value;
void delay ( int a )
	int i,j;
	for ( i = 0; i < a; i++ )
		for ( j = 0; j < 1275; j++ );
void lcd_init ()
	lcd_cmd(0x38);
	delay(5);
	lcd_cmd(0x0F);
	delay(5);
	lcd_cmd(0x0C);
	delay(5);
	lcd_cmd(0x80);
	delay(5);
void lcd_data ( char y )
	RS = 1;
	P2 = y;
	EN = 1;
	delay(5);
	EN = 0;
	delay(5);
void lcd_cmd ( char z )
	RS = 0;
	P2 = z;
	EN = 1;
	delay(5);
	EN = 0;
	delay(5);
unsigned char read_data()
	unsigned char i;
	char result;
		CS = 1;
		delay(5);
		CS = 0;
		CK = 1;
		delay(5);
		CK = 0;
		delay(5);
		CK = 1;
		delay(5);
		CK = 0;
		delay(5);
		for ( i = 0; i < 8; i++ )
			CK = 1;
			delay(5);
			CK = 0;
			delay(5);
			result = result << 1;
			result = result | DO;
			delay(5);
	return result;
void main ()
	lcd_init();
	while(1)
		value = read_data;
		lcd_data (value);
