[SOLVED] (HELP!!)Linear PCM BitRate and analog signal BW Relation
yjlum
Hi Guys, appreciate any help and input on the following problem
An analog signal is to be converted to digital signals using linear PCM with 256 quantization levels and transmitted over an 8 kHz band-limited channel. Assume that binary baseband transmission is employed. Ans: (a) Rb = 16 kbps. (b) B = 1 kHz.
(a)Find the maximum PCM output bit rate.
Rb(max)= 2*BT
= 2*8KHZ
=16kbps
=> how do you know that this is the max bitrate?
=>why can't i use Rb=n*fs=n*2*B
=8*2*8KHZ??
(b)What is the corresponding maximum analog signal bandwidth that can be accommodated?
=>Here is the problem that i am facing, how do you get the analog Signal BW from the Bit Rate?
Thanks for your time!
Nyquist gives us that a 8KHz channel bandwidth supports 16k baud (from his famous telegraphy eqn) and we are using a 2 level (binary) code, so 16 k baud = 16kbps.
You get the analogue bandwidth from the bit rate by noting that 256 level quantisation is 8 bit quantisation, and that 16kbps/8 bits = 2k samples/s
As you require the sample rate to be strictly greater then twice the channel bandwidth, 2k samples/s the channel bandwidth must be limited to just less then 2k samples/s / 2 = 1khz.
HTH.
Regards, Dan.
