hemnath
Advanced Member level 3
Hi Friends,
I'm interfacing KS0108 GLCD with PIC18F4520 controller. Compiler: CCS C. I have read the datasheet of KS0108 GLCD. But still i feel difficult in writing the code. I want to display "Hellow" in GLCD.
As a newbie in Graphic LCD, i tried CCS example and it was working good.
All i want to do is, making my font size as flexible. In CCS C compiler, there are only 2 font sizes which are 5x7 and 10x14. There are some instances where i will display some big size characters than 10x14. Also in CCS, there are inbuilt commands to use the X and Y addresses.
Now I'm writing the code as mentioned in datasheet. I want to display a character 'H' in the display. Please check initialization is correct? how to define hex values for character 'H'? Please help.
Thanks in advance.
HTML:
unsigned char data[] = {127,127,8,8,127,127,0,0}; // H, 8x8
void GRAPHIC_LCD_INIT()
output_high(RESET); // RST connected to PIN_C0
output_high(CS1); // CS1 connected to PIN_B0
output_high(CS2); // CS2 connected to PIN_B1
glcd_cmd(0x3F); // Display ON
glcd_cmd(0xB8); // Page selection - Page 1
glcd_cmd(0x40); // Column selection
void glcd_cmd(unsigned char c)
output_d(c);
output_low(RS);
output_low(RW);
output_high(EN);
delay_ms(15);
output_low(EN);
void glcd_data(unsigned char z)
output_d(z);
output_high(RS);
output_high(RW);
output_high(EN);
delay_ms(15);
output_low(EN);
void main()
GRAPHIC_LCD_INIT();
while(1)
glcd_cmd(0xC0); // display start line
glcd_data(data);
Thanks in advance.
