Port Map
I have to sample frequency range from 500MHz to 3 GHz. I need IF BW of 500MHz in any center frequency in that range.
I need about 70dbc dynamic range.
I'm new in RF design and I think in first step the signal should be up converted to a upper frequency with a LO like 8 GHz then down converted to IF frequency. after that a 1 GHz ADC can be used for sampling.
does any body know that:
Is this a good solution?
Is there are any board or device that can be used for this project?
