help in 8B10B coding of high speed link transceiver
BMR
Member level 5
Sweden
help in 8B10B coding..
I am doing a project on high speed link transceiver. I have a block called 8B10B encoder. I read the article in wiki about it , but i couldn't understand exactly why its is used.
FvM
Super Moderator
Staff member
Bochum, Germany
The method is used in most high speed serial data transmissions. By recoding each data byte to a 10 bit sequence, you get these features:
- clock recovery is possible because level transitions occur at least after 4 bit times
- the bitstream is DC-free and can be AC coupled
- special characters allow data synchronisation
    BMR
