help:I am a student in China started with mcu
wangcao
Newbie level 2
hello,the experts on mcu all over the world.I am a student in China started with mcu.I want to know about how many popular microcontrollers
are available in the market,and the hardware and software envirement
of the chips.How can I code well on mcu .thank you.
wangcao 3,5,2004 in shanghai,China
get start : **broken link removed**
enjoy 8)
The first steps with PIC16f84 , this is the more easy for learn.
The programmer JDM,(hardware)
Icprog.exe the sofware for save the code to PIC´s
The assambler of MPLAB , from http.//www.microchip.com
Microchip have too much information , datasheets and
aplicattions notes.
At internet the PIC16f84 is very used. You can view examples.
The ATEML families are the pop Embeded MCU,
They use easily.
The most easy to enter into the microcontroller's programming job is learning how to use 8051. It is because many of this derivative is in the market. And the emulator board is easy available in Chinese.
HI,
1- 8051
2- PICs
3- AVR
4- HC
5- :)
Bye
hai,
go for philips mc .easy to buil isp in serial port.
easy to learn.
OK! Try what ever you want, but take care, this is not the end of your work, once you learned about microcontrollers then do not stop, try to learn more powerful microprocessors, because, When it comes to a simple floating poitn multiply operation, there is no normal microcontroller to do the job for you in a small time.
Best choise is mcu extended with in circuit debugging schemas.i.e PIC flash based with ICD(in circuit debugging)-debug over two pins,Zilog eZ8-debug over 1 pin,Atmel. With that you can do debugging in real time in real your schema.
Learning how to use 8051 is the most easy to enter into the microcontroller's programming job .
hello dear
i from pakistan
i have worked on atmel
they are fine and having 4,8,20 k byte flash normally
maximum clock 24 mhz but in any case plz check iternal division clock
as in atmel external oscilater clock is divided by 12
it mean execution clock or machine cycles r 2 mhz
in pic iternal division is by 4
i can help u in case of atmel
if u wanna mail me at ghniazi@yahoo.com
ican help u in basic projects to go throuh
bye dear
I think the 8051 is the best chose for begginers.
Good tutorial here-> www.8052.com
Thanks!
/Warning #1 - Do not post useless messages. (klug)/
If you like pascal then try AVRco Multitasking Pascal at www.e-lab.de with powerfull Atmel AVR MCU family.
Avra
but the most hot!!! mcu in today is arm7....
you can go to phillps, atmel company..
is the choice of the next decade......
