hello,the experts on mcu all over the world.I am a student in China started with mcu.I want to know about how many popular microcontrollers
are available in the market,and the hardware and software envirement
of the chips.How can I code well on mcu .thank you.
wangcao 3,5,2004 in shanghai,China
The most easy to enter into the microcontroller's programming job is learning how to use 8051. It is because many of this derivative is in the market. And the emulator board is easy available in Chinese.
OK! Try what ever you want, but take care, this is not the end of your work, once you learned about microcontrollers then do not stop, try to learn more powerful microprocessors, because, When it comes to a simple floating poitn multiply operation, there is no normal microcontroller to do the job for you in a small time.
Best choise is mcu extended with in circuit debugging schemas.i.e PIC flash based with ICD(in circuit debugging)-debug over two pins,Zilog eZ8-debug over 1 pin,Atmel. With that you can do debugging in real time in real your schema.
hello dear
i from pakistan
i have worked on atmel
they are fine and having 4,8,20 k byte flash normally
maximum clock 24 mhz but in any case plz check iternal division clock
as in atmel external oscilater clock is divided by 12
it mean execution clock or machine cycles r 2 mhz
in pic iternal division is by 4
i can help u in case of atmel
if u wanna mail me at ghniazi@yahoo.com
ican help u in basic projects to go throuh
bye dear
