help,how to add bonding pad in soce
lightcloud
Member level 4
I want to know how to add bonding pad in soc encounter
thanks a lot!
shelkerahul
Member level 4
Bangalore
you need to do some scripting for that. first you need to add bondpad in your design , then place it at proper place. use following commands
addinst -cell <master_cell_name> -loc <X> <Y> -inst <inst_name>
placeInstance <inst_name> <X> <Y> <orientation> -fixed
this will work.
sheik_vb
Member level 3
What you mean by BONDPAD????
lightcloud
Member level 4
Bonding pad is used to connect io pad to package pin. and when I used
the method in soc encounter,after doing verification, I find very lot overlap
and short violation between io pad and bonding pad.shoud I check it?
and how to decide the oritentaion of the bonding pad?
thanks a lot!
Added after 2 minutes:
I want to if it appear new drc vioalion after add the bonding pad?
