Help for a line in voltage question.
kostbill
Full Member level 1
Hello. I am designing a system for audio processing.
The problem is I am not good at analog electronics. The manual of the IC I am using, is saying that:
"The ADC full-scale range is 1.0 VRMS at AVDD = 3.3 V. The full-scale range tracks linearly with analog supply voltage AVDD. To avoid distortions, it is important not to exceed the full-scale range."
I am totally lost here. What does it mean? 1 Vrms = squareroot(2)/2? So my maximum voltage must be 0.354 Volt? And after the ADC, again, the maximum voltage I am going to use in order to convert my integer values into floating point numbers, will be 0.354 again?
Thanks for any help.
For ac signal 1Vrms means only that the positive peak is at 1.41V and the negative peak is at -1.41V ..
Your ADC can work between GND (0V) and Vdd (3.3V) ..
Just imagine you set the reference (DC offset) for the 1Vrms signal at Vdd/2 = 1.65V ..
If you do this you’ll never exceed the ADC’s full scale range (1.41+1.41=2.8 --- full range=3.3) ..
See the attached drawing ..
IanP
:wink:
