Help!!! Escape sequences in C++ on windows XP
Lucifre
Full Member level 2
Detroit MI
Hello, i am learning C++ and i try using escape sequences but they don't work since i am using windows XP. I tried modyfing Config.nt and adding
device=%SystemRoot%\system32\ansi.sys
to it, but it doesn't work!! even if i restart the comp. Any experts out there that know how to make escape sequences in C++ programs work on windows XP?
Can you post your code snippet? I don't the problem here. You are refering to a variable set in the environment and not in a C or C++ program.
Hows this :)
All "special characters" must be escaped!
#include <string>
#include <fstream>
using namespace std;
int main(int argc, char* argv[])
	string szFilename = "C:\\test.txt";
	string szBuffer = "device=%SystemRoot%\\system32\\ansi.sys\n\r";
	ofstream outfile( szFilename.c_str(), ofstream::binary );
	outfile.write( szBuffer.c_str(), szBuffer.length() );
	outfile.close();
  return 0;
Remmeber newlines are different for:
LF: Unix
CR+LF: Microsoft Windows
CR: Apple
In future post:
a) What you are trying to do.
b) Where you are stuck.
c) Any appropriate code snippets and information.
Hope that helps! :)
When i was reffering to escape sequences i meant Ascii escape sequences like the ones that clear the screen or the ones that move the cursor in dos window
for example when i try to use move cursor escape sequence in a macro
 # define MOVETO(z,s) (cout <<"\033[" << z << ';' << s << 'f')
i get output somethin like: 033[z;sf and the cursor doesn't move
my book says it is becaue windows XP isn't dos based, but there are ways to make them work
