boulderjoe
Newbie level 1
I'm a novice in the circuit world and could really use a hand designing a seemingly simple DC Motor control circuit. I have a 0-5VDC ~100mA signal I need to convert to a 24VDC 2A signal. PWM would work fine, but I also don't really care about dumping the heat. I have 24VDC already available. Exact 0-24 isn't necessary. Leak through ICs is fine. What kind of ideas do you guys have? I tried to use an LM324 along with a LM675 (power amp) but it didn't work. I think I had some kind of grounding problem. I'm also trying to keep the circuit as simple as possible. Any ideas would be great.
Thanks again,
Joe
Thanks again,
Joe
