In my soc, there are some clock sync DFF. For example, in usb module, there are some DFFs use clk_48 as clock and clk_12 as data, that means in normal function mode DFFs will use clock of clk_12 as data. But in scan mode, clk_12 and clk_48 will be one clock, that is test_clk, then in scan capture, these DFFs will capture violation. At first, I think this is the reason what lead to my atpg simulation fail. So when insert scan, I set_scan_element false these DFFs. But my atpg siulation fail too. I use ncverilog simulator, and use two parameter nospecify and zero_delay_mode.
How can i deal with this problem? Now I want to tmax do not care these DFF, is this doable? If yes ,How can do?
Thx.
