Help appriciated for this code......Thanks
Full Member level 1
India, Kerala, Moolamattom
Please help me with making of hex file from this code...I get this code from internet. Its LCD and PIC 12F628A based Timer.
Check this link.......**broken link removed**
Thanks in Advance
Hi Manoy,
I build hex file for you,
probably on this project was used RC osc,
I make hex file for project but with 10MHz osc (HS),
so you must use external OSC with 10 MHz,
best regards
  • for you.rar
Thanks Pasicr and Jayanth.....But still dont know how to work
The output LED not working after presss the start button..........
.......Please help me again with proteus simulation ?
Check the attachement..
now it is ok...Proteus simulation working well. But I burned the PIC Chip with the hex file, there has an error....and not completed yet....
I think need to config the programme memory....
Manoj, do you have possibility to use other programmer?
try to find some other PIC programmer, from some collegues...
regards
regards
Hello Peter,
Some chips programmed with my lynx bios programmer and its working well. In this case, I get some error message. Is the problem of hex file or the chips? The PIC16F676 is programmed only one time programmeble chips?
regards
Manoy,
hex file is not a problem,
you have problem with programmer or MCU
regards
p.s. Manoy,
I read in your previous posts many mcu:
you start with 12F628A, probably this is tipe error,
sch. show 16F628A, that is Ok,
I build hex file for you with 16F628A, with external osc at 10MHz,
in the last post you say 16F676,
please specify what is correct....
Manoy,
regards
p.s. Manoy,
Sorry for my Mistakes.
Its 16F628A. That correct.
I try to build a digital voltmeter with PIC16F676. Sometime I confused....Its my Mistake and Sorry.( I am new in PIC. Can you please help me to build a Digital voltmer with PIC16F676 ? .The shematic in the coolcircuit is not working. I have a working Model and I buy from market. Can you please?
can I attached the schematic and the proteus file, which I Trace from the working Model?
Zip and attach the Proteus file and mention the Clock freq and PIC used. I will compile the code for the other chip after checking the datasheet.
Thanks Jayanth.......
Finally I am making the 3 Digit Voltmeter.....Great stuff for me. and Thanks to attenssion about my request......*** BLESS YOU ALWAYS.
regards
Mention PIC that will be used and also Clock freq (OSC) used? External or Internal OSC?
Hi Jayanth.....
My 3 Digit voltmeter working perfectly.... So I have the new problem...I need an AC Voltmeter for 0-300 V measuring. I seeave the circuit and the Working Model. I dont have the hex file.... Can you please and see the attachment.
Regards
Convert ans scale your ac to dc 5V.
HTML:
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
#use delay (clock=4000000) // 4MHz clock
#rom  0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
#define SPORTA PORTA
#define SPORTC PORTC
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
    //                       0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int32 Num);
byte i;
unsigned int32 result;
#INT_TIMER1
void Timer1(void)
    set_timer1(TMR1RESET);
    Display();
void main()
    unsigned char i;
    CPU_SETUP();
    while(true)
        result=0;
        for (i=0;i<20;i++)
            set_adc_channel(3);
            delay_ms(1);
            result=result+read_adc();
            //result = 0x3fe;
        HTO7S(result/20);
        delay_ms(200);
void CPU_SETUP()
   setup_comparator(NC_NC_NC_NC);   // not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   TRISA=0b00011000;
   PORTA=0x27;
   TRISC=0b00000000;
   PORTC=0x37;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_TIMER1);
// Display routine
void Display()
    PORTA = 0b00100111;   // off all digits column and Segment G
    PORTC = 0b00111111;   // off segment a-f
    delay_cycles(2);
    if (ColCount>=3)
    ColCount=0;
    SPORTC = Segment[ColCount];
    SPORTA = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
    ColCount++;
// Convet HEX 2 byte to 7-Segment code
    unsigned int32 res;
    Segment[0]=SegCode[30*Num/10230];
    if (Segment[0]==0x40)
    Segment[0]=0xFF;
    res = 30*Num%10230;
    Segment[1]=SegCode[10*res/10230];
    res=10*res%10230;
    Segment[2]=SegCode[10*res/10230];
Is this the code for the AC 230 V meassurment?
can you give me the hex file for this code? I dnt knw that...Please...
I Think this is the right cod efor the above circuit
regards
