#include "LPC214x.H" // LPC2148 MPU Register
#include <stdio.h> // For Used Function printf
/* pototype section */
void init_serial0 (void); // Initil UART-0
int putchar (int ch); // Put Char to UART-0
int getchar (void); // Get Char From Uart-0
void delay(unsigned long int); // Delay Time Function
unsigned int val; // ADC Result (HEX)
float volt; // ADC Result Volt
int main(void)
init_serial0(); // Initial UART0 = 9600,N,8,1
printf("Input Voltage 0-3.3V to P0.6 For Test\n"); // Call prinff Function
// xxxx xxxx xxxx xxxx xx11 xxxx xxxx xxxx
PINSEL0 |= 0x00003000;// chon ADC1.0 Connect P0.6(pin30)
// Initial ADC8 (ADCR=0x01210601)
AD1CR &= 0x00000000;// reset all cotrol bit
AD1CR |= 0x00000001;// chon ADC1.0
AD1CR |= 0x00000600;// ADC Clock = VBP(PCLK) / 7
AD1CR |= 0x00010000;// Busrt = 1 cho phep lap lai convert A->D voi CLK adc da chon o tren
AD1CR &= 0xFFF1FFFF;// CLKS = 000 = 10Bit : 11 Cycle Clock Conversion
AD1CR |= 0x00200000;// PDN = 1 cho phep ADC Module tich cuc
AD1CR &= 0xF7FFFFFF;// EDGE = 0 = Conversion on Falling Edge
// Start Test Read ADC8 and Display on UART0 //
while(1) // Loop Continue
AD1CR |= 0x01000000; //now start conversation
while((AD1DR0 & 0x80000000) == 0); // wait ADC convert complete
val = ((AD1DR0 >> 6) & 0x03FF);
printf("gia tri tra ve: %o",val);
/* Initial UART0 = 9600,N,8,1 */
/* VPB(pclk) = 60.00 MHz */
PINSEL0 &= 0xFFFFFFF0; // Reset P0.0,P0.1 Pin Config
PINSEL0 |= 0x00000001; // Select P0.0 = TxD(UART0)
PINSEL0 |= 0x00000004; // Select P0.1 = RxD(UART0)
U0LCR &= 0xFC; // Reset Word Select(1:0)
U0LCR |= 0x03; // Data Bit = 8 Bit
U0LCR &= 0xFB; // Stop Bit = 1 Bit
U0LCR &= 0xF7; // Parity = Disable
U0LCR &= 0xBF; // Disable Break Control
U0LCR |= 0x80; // Enable Programming of Divisor Latches
// U0DLM:U0DLL = 60.00 MHz / [16 x Baud]
// = 60.00 MHz / [16 x 9600]
// = 390.6 = 391 = 0187H
U0DLM = 0x01; // Program Divisor Latch(391) for 9600 Baud
U0DLL = 0x87;
U0LCR &= 0x7F; // Disable Programming of Divisor Latches
U0FCR |= 0x01; // FIF0 Enable
U0FCR |= 0x02; // RX FIFO Reset
U0FCR |= 0x04; // TX FIFO Reset
U0FCR &= 0x3F;
/* Write Character To UART0 */
if (ch == '\n')
while (!(U0LSR & 0x20)); // Wait TXD Buffer Empty
U0THR = 0x0D; // Write CR
return (U0THR = ch); // Write Character
/* Read Character From UART0 */
int getchar (void)
while (!(U0LSR & 0x01)); // Wait RXD Receive Data Ready
return (U0RBR); // Get Receice Data & Return
/* Delay Time Function */
/* 1-4294967296 */
void delay(unsigned long int count1)
while(count1 > 0) {count1--;} // Loop Decrease Counter
