I must create FSK like ”pulse” signal and must with jitter
--> I use idea switch and many source merge this signal
if I want to generate FSK signal
if I want to generate Eye diagram random pulse
if I want to gernerate FSM signal + rise/fall edge with jitter overshoot waveform
I only use spice tool .. by the way , matlab can convert code to hspice ??
I know some tool like saber/smash support C like
can describe source , but hspice not support ,
I looking for a software like "Waveform Pro"
can generate spice signal for simulation
You must go to http://www.microwind.org/ this new Layout tool from Etienne Sicard is realy cool, I used it and love it...you can get the eye diagram directly from the layout simulation...awsome eh...
Well Matlab can help you because MAtlab can work with C++ files,java and Visual Basic.
But to do it is a little bit tricky, aas I remeber u must study and understand the MAtlab GUI
