drkirkby
Full Member level 6
Has anyone got a 64-bit version of the T-check software from Rohde & Schwarz ?
I came across this application note from Rohde & Schwarz
It describes a way of checking the calibration of a VNA using a T-junction. I was not aware of this method until I read the R&S application note. It appears if you have a lossless 3-port network, with port 3 terminated in a load with some resistance, there's a relationship between the four S-paramters S11, S12, S21 and S22, which can be used to verify the calibration of a VNA. Apparently all one needs is a .s2p Touchstone file and this T-check software.
The trouble is, I can't find T-Check on the Rohde & Schwarz web site. The nearest I got to getting a copy of this program is an amateur radio site
http://www.hamcom.dk/VNWA-E.html
aimed at the low cost VNAs from SRD-kits http://www.sdr-kits.net/ That has a copy of the program, but it will not run on my 64-bit Windows 7 machine. I'm just in the process of setting up a 32-bit XP virtual machine with VirtualBox, with the aim of runing the program on that, but it is a bit of a pain to have to use a virtual machine.
Dave
Dave
