bobbywu
Junior Member level 1
i have make inverter with unipolar pulse width modulation. the signal switching is 3Khz on 50 Hz as frequency fundamental. The harmonic occur in 6Khz.what happen if i use single phase motor as load. what the diiference about low order harmonic and high orde harmonic?thanks...
